raz747
#1 Posted : Tuesday, March 9, 2010 11:44:05 AM(UTC)
raz747
I have a Jenn-Air stove/oven combo with self cleaning feature. A wire has corroded off the micro switch and shorted. I need that micro switch and wire fitting to reconnect it. Part numbers on the part are:
E3405LT and 202806. It is on schematic station 19. The metal arm that actuates the microswitch is on the right of the switch with the metal arm pointing toward the front of the oven. Can you help?
thanks,
richard
magician59
#2 Posted : Tuesday, March 9, 2010 12:39:46 PM(UTC)
magician59
Here's the part number. Part number: AP4087563
raz747
#3 Posted : Tuesday, March 9, 2010 1:19:58 PM(UTC)
raz747
Thanks for showing that part. The one I need is just the opposite of that with the micro switch actuator lever on the right facing the front of the stove but I think I may have found one.
Thanks for the help!
richard
