Looney102
#1 Posted : Sunday, March 7, 2010 8:19:32 AM(UTC)
Looney102
As the title shows I have a Frigidaire Oven/Stove top /Range model # fef326abg When i turn the Large burners on the element light comes on but i get no power or heat from the 2 large burners. The small ones work fine but the large ones won't get any power to them.
I looke and i see no burnt wiring and there is power to the switch. I don't know much about ranges and i have no idea what to check next.
Any help would be greatly appreciated
Thanks,
Robert
#2 Posted : Monday, March 8, 2010 3:27:49 AM(UTC)
Replacement parts for FRIGIDAIRE FEF326ABG Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255302.pdf
And a manual though I do not know how closly it matches your unit
http://frigidaireservicetips.com/pdfs/304_5995361523_NGInchFreestandingRanges_revA.pdf
You have a weird problem.
I cannot see how the two large elements have any wiring that is just for the two of them.
I am assuming they both went out at the same time and that everything else works properly.
I would check them for resistance, perhaps they both went out at the same time though the odds of this happening are very, very high.
Also recheck the wiring.
I am pretty well stumped on this one
Hopefully, someone else will be more helpful.
Looney102
#3 Posted : Tuesday, March 9, 2010 7:15:36 AM(UTC)
Looney102
Looks like i'm goin to havre to call a repair tech :-\
