The error code looks like an 'E5' without the top line of the 'E'. Or it could be an 'L' without the middle line showing on my display.
Either way, the dryer won't start. All components check-out 'Ok', but it's just not starting. Could the circuit board need replaced? :confused:
Thanks in advance!
Originally Posted by: skalesplitur ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The error code looks like an 'E5' without the top line of the 'E'. Or it could be an 'L' without the middle line showing on my display.
Thanks in advance! I have the same error code on my dryer, E5 with the top bar in the E missing. Does any body have a repair solution for it?
