MRANDMRSCCOL@HOTMAIL.COM
#1 Posted : Saturday, March 6, 2010 11:06:17 AM(UTC)
Drum turns, does not heat. Took apart, nothing appears to be burnt, checked all the wires, plugs, terminals. any help would be appreciated:)
#2 Posted : Sunday, March 7, 2010 1:47:57 AM(UTC)
Replacement parts for FRIGIDAIRE GLER341AS2 Frigidaire/electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/131850600.pdf
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 12 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Be sure to disconnect one side of and device you are measuring this prevents reading an alternate/parallel circuit path. Also use your most sensitive ohms scale.
There is a good Sticky at the beginning of this forum on meter usage.
