Hi, I just put a new pump and belt in my washer and It still won't get the water out intill I turn the knob back to rinse? What up with that?? This is why I put a new pump and belt in it in the first place. The washer was not rinsen out! Everything works like it need's to the first time but doesn't rinse out??? Can you help me?? Thanks,James H :confused:
Did you check the drain hoses for a kink or some kind of obstruction? If they're clear, can you hear the motor try to spin?
:confused: Originally Posted by: magician59  Did you check the drain hoses for a kink or some kind of obstruction? If they're clear, can you hear the motor try to spin? Yes, I did check the hose and the motor runs! If I run it like normal everything works intill it get's to the rinse cycle and it doesn't empty the warter out? So I turn it back to rinse and it will empty then. I Don't know ??? Thanks,James:confused:
It sounds like you may have a bad timer.
Originally Posted by: magician59  It sounds like you may have a bad timer. I'll try that! :rolleyes: Thanks, I'll let you know james,;)
