After a power failure the LED display shows the time and OFF. The time can't be reset and none of the oven buttons work. If you push Cancel it beeps and that's about it. The stove top burners work but not the oven or the lights. I have unplugger the unit and left it for about 30 minutes but when repugged it reamins the same.
Originally Posted by: magician59  Thank you that worked. I had contacted a repirman who told me it was the clock mech and it would cost $350 to $400 to replace it. I had started looking for a new stove. Thank you very much.
If only I could always save money on my own appliances like that... Glad to help.
Thank you. I had the same problem after a power outage. I downloaded the oven manual but it did not help. Finding help with a problem by using these kinds of forums on the internet is excellent!
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Rank: Guest
Rank: Guest
