jakemdr
#1 Posted : Thursday, March 4, 2010 7:46:38 PM(UTC)
jakemdr
HI.
NO HOT OR WARM WATER, AND YOU CAN EAR SOME BUZZING OR HUMMING NOISE.
WEN ON TO GET HOT OR WARM WATER, NO BUZZING ON COLD WATER.
I LOOK @ WATER LINE OK, CHANGE WATER VALVE, CHANGE ANALOG HOT WATER TEMP BOARD, CHANGE TIMER,
!!!!!!!NO HOT WATER AND IT BUZZING AND HUMMING!!!!!:o :o
SO IS MY WALLET.
CAN SOMEONE'S FIGURE THIS OUT.
THANKS JAKE,:confused: :confused:
magician59
#2 Posted : Friday, March 5, 2010 7:20:18 AM(UTC)
magician59
If the valve is buzzing when hot water is called for, make sure the hot water is turned on at the source.
jakemdr
#3 Posted : Sunday, March 7, 2010 9:52:35 AM(UTC)
jakemdr
thanks for the quick reply, I was out off town and did not reply till I check the water supply.
No it's all connected and water is there. I switch the hot & cold, the problem still there's.
Jake
jakemdr
#4 Posted : Sunday, March 7, 2010 10:59:16 AM(UTC)
jakemdr
Jake
Also wen auto temp control is on. No warm/warm no warm/cold only cold/cold is run. Wen cancel, I got cold water on all selection, but not any on hot/cold
Jake
magician59
#5 Posted : Sunday, March 7, 2010 4:42:17 PM(UTC)
magician59
Reverse the connectors on your water inlet valve. Select "Hot" and see if cold water comes out. If not, replace the timer. Just for giggles, while the connectors are reversed, select "Cold" and see if you get hot water. If not, replace the timer AND the valve.
jakemdr
#6 Posted : Sunday, March 7, 2010 8:40:23 PM(UTC)
jakemdr
Wow,
You do have to be a Magician to figuring this one out.
It was the hot water supply,it has auto flows control. that Was Faulty, wen I took it off the water runs, hooked back on, pressure build up and boom no water.
Thanks for your helpful tips, by reversing connectors on water valve and water line it is All works perfect now.
Thanks.
Jake
Guest (4)
