i ordered a flat igniter but it won't work, even though there is 115 volts supplied to it when the oven is turned on. the igniter does not glow! now i went back on the site and it seems although it looks like the identical part, i ordered the wrong part. i should have ordered part #ap2150412 instead of part #ap205873???? depending on how you search for your part--by model # or by part discription you come up with different results???
so im my opinion this part requires 230 volts to operate and wn't work in you tappan oven
hey thanks!! i ordered the right part this time -- model specific and it should arrive monday i'll install it then and let you know how it goes thanks again
yes please let us know how it goes i'm anxious to see if your oven will work now!!
anyone??? anybody know the answer???? to the original question??
