well The deal is we just changed the water inlet valve and the auger and drum,the auger and drum where both damaged we could see that and the water dispinser did not work so it was obvious that the inlet valve was messed up,but now its all changed and although the water dispinser is working perfect no ice has made,so someThing is still wrong and we are trying to trouble shoot it somehow,SOMETHING IS STILL WRONG,the ice will not make.:mad:
hI,MY HUSBAND JUST TOLD ME SOMEHING NEW,HE SAYS THAT THE WATER VALVE IS WORKING ON THE WATER SIDE BUT THE VALVE FOR THE ICE SIDE IS NOT WORKING AND HE THINKS ITS SOMEHOW SHUT OFF,THIS IS A BRAND NEW PART HE JUST INSTALLED
