wrohrer
#1 Posted : Wednesday, March 3, 2010 9:35:01 AM(UTC)
wrohrer
Is it possible to repair a small hole, 1/2" in diameter, in the white plastic interior panel of a Maytag refridgerator and make it look okay?
where can I obtain product to do so?
magician59
#2 Posted : Wednesday, March 3, 2010 10:06:32 AM(UTC)
magician59
Buy a cheap vinyl report cover to (approximately) match the interior color of your appliance. Cut a square, just larger than your hole. Super-glue it over the hole. Or go to Home Depot or Lowe's and buy an electric hole plug (called a "push penny") to match the size of the hole. It'll fill the hole, but it's stainless instead of plastic.
wrohrer
#3 Posted : Wednesday, March 3, 2010 4:17:34 PM(UTC)
wrohrer
Thanks I will determine which is the most appropriate for this instance.
Wrohrer
wrohrer
#4 Posted : Wednesday, March 3, 2010 7:46:08 PM(UTC)
wrohrer
Is there a particular epoxy or glue that works well on the plastic panels on the inside of the Maytag refrigerators?
I have figured out how to cut an old drawer piece to perfectly fit and patch a hole but I need an epoxy or plastic sglue that WORKS.
