orionlbb
#1 Posted : Sunday, February 28, 2010 5:51:51 PM(UTC)
orionlbb
I have removed a WB27K5273 wall oven control board to replace it with a new WB27T10265 control board.
The new board has an extra connection on the bake block, and two extra on the broil block. How do I hook this up? I bought it from appliancepartpros.com and it came with no instructions at all..
Please help!
thanks!
here is the old board (Top ) & the new board.
The connections in question are around the "black box" components.
On the old version there is a Bake wire, a Broil Wire and a L1B Wire.
One the new board the bake block has a NO and COM connector, on the Broil block there is a NO, NC and COM.
So where do I hook up the single wire for the Bake? I'd expect NO, but doesn't something go to the COM connectors?? Same for the Broil. I'd expect the L1B gets connected there are well...
[IMG]http://www.flickr.com/photos/10908255@N02/4401223345/[/IMG]UserPostedImage
URL for larger photo - http://farm5.static.flickr.com/...1223345_3127d60d75_b.jpg
orionlbb
#2 Posted : Monday, March 1, 2010 6:16:37 PM(UTC)
orionlbb
So the I the support I've received is ""Wiring may be different from the original and may require a technician to install""
Time to return the board?!?!:confused:
orionlbb
#3 Posted : Tuesday, March 2, 2010 9:22:46 AM(UTC)
orionlbb
[IMG]http://www.flickr.com/photos/10908255@N02/4401223345/[/IMG][IMG]http://www.flickr.com/photos/10908255@N02/4401223345/[/IMG]
orionlbb
#4 Posted : Thursday, March 4, 2010 10:11:16 AM(UTC)
orionlbb
Anyone??? Ideas??
ksthompson
#5 Posted : Saturday, May 1, 2010 4:36:38 PM(UTC)
ksthompson
Did you ever find an answer on where to put the L1B connector for this--We are having the same problem.
ksthompson
#6 Posted : Monday, May 3, 2010 3:53:16 PM(UTC)
ksthompson
I figured it out. The L1b wire from the old control plugs onto the broil relay on the new control.
Guest (5)
