orionlbb
#1 Posted : Sunday, February 21, 2010 11:39:56 AM(UTC)
orionlbb
I have a GE wall oven, runs up to temp & has intermittent F3 errors, sometines F4 and F5. Usually can be cleared , but its a pain t shut it off & restart over & over.
I checked the temp probe - 1.083 K-ohms, so that looks right. I don't see this model number on this website to get part numbers for the control panel...
Need help with the part numbers, or any other ideas..:cool:
ApplianceJunk
#2 Posted : Sunday, February 21, 2010 1:58:04 PM(UTC)
ApplianceJunk
Are you sure your model number is correct?
Could it be model number: JTP27WW1WW
orionlbb
#3 Posted : Monday, March 1, 2010 6:14:37 PM(UTC)
orionlbb
Yup that is the correct number from the double oven.
I actually bought a replacement control panel, but I am at a standstill now since the connector patterns aren't the same, and no instructions were included.
The only help I got was ""Wiring may be different from the original and may require a technician to install""
