D_Druz
#1 Posted : Monday, March 1, 2010 4:41:38 PM(UTC)
D_Druz
After pressing the start button, the dryer does not crank over. It sounds like it is willing to turn over, but after pressing the start button for another 10 seconds, the dryer simply dies.
Qtip
#2 Posted : Monday, March 1, 2010 7:18:48 PM(UTC)
Qtip
sounds like it could be the motor going bad. you will probably need a 2nd person to do this but you will need to open the dryer door and hold down the door switch.. at the same time you'll need to push the start button and manually turn the drum by hand (all 3 of those at the same time) and if it fires up you've got a motor thats going bad but this will buy you a little time to replace it. even if it doesnt fire up that way you still probably have a bad motor unless there is something like a sock stuck in the blower wheel. does the dryer hum when you try to start it?
electric dryer does not start (Microwave Repair)
by RayU 12/12/2013 7:03:52 PM(UTC)
Dryer does not start (Dryer Repair)
by Kalalau 9/20/2012 12:20:37 PM(UTC)
by hibidwns 6/25/2012 1:44:16 PM(UTC)
by Bharat 1/7/2012 4:02:37 PM(UTC)
Dryer does not start, can hear motor attempting to (Dryer Repair)
by bog 11/5/2011 9:52:03 AM(UTC)
by Raymond S 8/4/2011 8:35:52 AM(UTC)
by cpboudreaux 2/15/2011 8:59:37 AM(UTC)
Dryer does not start - Amana Gas (Dryer Repair)
by timjgtr 1/8/2011 10:10:33 AM(UTC)
Dryer does not start at all (Dryer Repair)
by timjgtr 12/26/2010 2:40:08 PM(UTC)
Gae Dryer Does Not Start (Dryer Repair)
by B Wall 9/10/2010 7:03:40 AM(UTC)
Dryer does not start, makes no sound (Dryer Repair)
by Pennell 11/12/2009 5:17:16 PM(UTC)
dryer does not start (Dryer Repair)
by petecardenas 10/19/2009 8:17:02 AM(UTC)
by petecardenas 10/19/2009 8:15:29 AM(UTC)
by bellaboo 10/1/2009 1:16:49 PM(UTC)
Amana dryer does not start (Dryer Repair)
by Barjensen 8/5/2009 4:21:07 PM(UTC)
