The microwave counter is still working (it counts down) but the microwave wont heat the food. the light turns off and there's no humming noise thats there usually when it works. any advice would be rrreaaalllyy helpful.:)
Most likely the problem is a bad secondary interlock switch (on the door frame).
The model number you posted does not come up and I'm not able to provide more accurate advise.
Thanks alot Gene for your reply. i found some other numbers that i hope might be helpful. im not really tech saavy so i dont know much about different parts of the microwave or others. The FCC id:AKS9PE031 other numbers include: PN 75409-01, 35-059831-05-0, and 651B267P4. i hope that is helpful. and i really thank you Gene for your help.
What kind of a microwave is it? Built in a cabinet, over the range, counter top of a combination with an oven?
its a built-in microwave that is also a combination with an oven. it says solid state modern maid twin wave.
If there is no model number inside the microwave then check the oven door frame for the name plate.
actually the above numbers were the only ones i found on both the oven and the microwave.
Well, no one of them looks like a valid model number.
In order to access the door switches you have to remove the control panel and I can not tell you how do it without proper model number.
If you can post a pictures of the unit it might help.
