gse
#1 Posted : Sunday, February 28, 2010 11:22:02 AM(UTC)
gse
defroster not working
#2 Posted : Monday, March 1, 2010 2:48:10 AM(UTC)
Replacement parts for MAYTAG MZD2768GEB Ref - SXS/I&W | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Try forcing a defrost cycle, see Page 2-15 in the manual.
With this unit it may be just as easy to check the defrost heater and defrost thermostat with a meter. Then if both are OK assume that the defrost board is the problem.
