gene1141
#1 Posted : Wednesday, April 9, 2008 5:13:22 AM(UTC)
gene1141
The ice dispenser door won't close. Thanks for any help.
#2 Posted : Thursday, April 10, 2008 10:23:04 AM(UTC)
Gene,
Use a screwdriver to unlock the tabs at the bottom of the dispenser control panel. Slide the bottom out and down.
Disconnect the wiring harness connectors.
Put the dispenser control panel aside.
Remove the four screws in the door dispenser housing.
Slide out the housing and disconnect the target switch and dispenser light connectors.
Spread out the locking tabs and remove the switch.
Push the chute duct door locking tabs back and raise the assembly above the locking tabs.
Push the lower armature locking tabs (under the assembly) back and lift up the entire assembly.
Check all parts shown on the attached diagram.
Post your findings.
Gene attached the following image(s):
Bar between side by side ref. door is hot (Refrigerator & Freezer Repair)
by crazyoma 5/17/2013 3:09:25 PM(UTC)
Amana Side by Side Ref. (Refrigerator & Freezer Repair)
by sandraandlarry 2/25/2013 1:03:08 PM(UTC)
