llutonhodges
#1 Posted : Sunday, February 28, 2010 1:47:07 PM(UTC)
llutonhodges
Gibson freezer stopped working.
#2 Posted : Monday, March 1, 2010 2:03:23 AM(UTC)
Replacement parts for FRIGIDAIRE GFU17M4GW1 Gib(v0) / Freezer | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/216751700.pdf
You have to do more trouble shooting.
Is the compressor running. It should be warm and you should be able to feel or hear it vibrating.
If it is running then you have a sealed system problem and it will be expensive to repair.
If it is not running then it could be the thermostat, the compressor itself or it's start relay.
