Dishwasher is not drying dishes
A model number may help others help you.
Remove power from the unit, remove one wire from the heating element and check it with a meter.
Also most unit have a hi-limit thermostat wired in series with the heater. It should be 0 ohms at room temperature. |
THIS FORUM IS DEAD!!!!!!! |
