The latch on our Kenmore Microwave broke. We just received the new latch but it didn't include instructions. We can't see any screws on the door. The microwave won't work without the latch operating properly. Can anyone help?
Is this what youre replacing? (or something that looks like it)
Thanks for replying. Yes, that is the part.
If there are no screws to hold the inside door cover in place then they are probably using snap or lock in tabs around the edges to hold it in place. I don’t know “exactly” where each tab would be located. But it’s going to be a case of carefully going around the edges with a tool in order to release each of the clamping tabs in order to remove the inside cover.
