pcijohn
#1 Posted : Wednesday, August 29, 2007 8:43:22 AM(UTC)
pcijohn
How do I unlock the door. It seems to locked as the result of an F11 code. I can't even unlock the door to figure out which model I have. Any help would be wonderful!
fvas
#2 Posted : Wednesday, August 29, 2007 9:06:25 AM(UTC)
fvas
I failed to say, my Maytag is a Model MAVT236AWW, top load. It is ten months old and will not drain after installing a new belt. It just clicks.
#3 Posted : Wednesday, August 29, 2007 7:16:26 PM(UTC)
Hi fvas
The first thing I would check is the belt installed properly. It could came off the pump pulley and stuck between the pulley and the body of the pump.
Good luck.
#4 Posted : Wednesday, August 29, 2007 7:43:07 PM(UTC)
Hi pcijohn
According to the repair manual to manually unlock the door you have to:
- Unplug washer or disconnect power.
- Remove the lower kick panel.
- Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
- Located on the bottom of the door switch/lock unit is a teardrop shaped tab.
- Gently pull the tab down about a 1/4˝ or until a click is heard.
- The door may be now opened.
Good luck.
Guest (4)
