replaced panel control in dish washer worked fine for a couple of times. then clean light keeps blinking and i cant get it to keep blinking
Blinking clean light has nothing to do with the control panel. It shows that the control senses something wrong in the heating circuit. You have to check the heater and the high limit thermostat for continuity.
thanks gene where can i find a diagram for the heater stat marko 123
how can i find the high limit for my heating cirkit
What is the end of the model number?
complete # is kudso1flss6 i think i found it 1 orange wire goes to this part at front of dishwasher 1wire white with a purple stripe goes to wire harness going into door both wires are coming from heater the wire coming from front of door with orange wire is going to wire harness going into door its color is white and red thanks marko 123
I believe you found the right part. It's shown as #30 on the diagram and the wires color is in accordance with the Wiring diagram. remove the wires and check the part for continuity. - The high limit thermostat Part number: AP3010530
is that a reset button i see my part doesnt have that mine sits against bottom of tub with 2 wires coming off of it that has to be the problem the heater has continuity does the diagram show where its located thanks marko 123
This thermostat is not resettable. It is mounted on the bottom of the tub ans is shown as #30 on the diagram. You have to check it for continuity and if there is nothing wrong and there is no broken wires, then the problem very likely is a bad control board.
if its the control board what part # is it any chance of getting a diagram and parts list on my model thanks marko 123
