How do i remove the front panel of the dryer so i can clean out the cabinet?
Inside the door jam on the top are screws which you can remove. This will allow the top to come off. You can then take out the two screws that hold the front.
Make sure you disconnect the door switch and mark how the wires go so you can put it back.
