mmalone2
#1 Posted : Wednesday, April 9, 2008 5:02:11 PM(UTC)
mmalone2
How do you force a manual defrost on a fridge with a control board. I have a GE GSS22JFMC side by side. No owners manual.
#2 Posted : Thursday, April 10, 2008 12:31:32 PM(UTC)
As far as I know there is no way to do it.
What is the original problem with your fridge?
mmalone2
#3 Posted : Thursday, April 10, 2008 6:11:15 PM(UTC)
mmalone2
The original problem was the coil in the freezer iced up. I wanted to put it in to defrost so I could check the heater and the defrost thermostat.
#4 Posted : Thursday, April 10, 2008 8:01:59 PM(UTC)
You can check the defrost heater and the defrost thermostat for continuity. Both of them should be closed (the defrost thermostat must be cold at the test time).
#5 Posted : Friday, April 11, 2008 1:27:10 AM(UTC)
You can manually force defrost. Remove the back metal panel to expose the motherboard and unplug the power plug on the bottom left. Stick a jumper between the J11 and J 8 connector pins. The pc board will have these pins labeled. Now plug in fridg. The defrost heater will now draw current, if yes, you probably have a bad motherboard item # 801. They also recommend to also replace the freezer thermister. If not, you have a bad defrost heater or thermostat. Very common for the heater to fail on these.
appliancemagic
#6 Posted : Friday, August 22, 2014 9:27:19 PM(UTC)
appliancemagic
Its J9 & J11, J8 Is To The Compressor and Fans.
Guest (6)
