AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Breaker trip before spin cycle, spin not working
Rank:: Member
Groups ready for retrieval: Registered
Washing machine ( FRIGIDAIRE FWSB6600FS0 Frigidaire/washer)
Stops and trips breaker before spin cycle, after resetting the breaker the spin cycle will not work.
!!!updated below!!!
Rank:: Member
also just tested and when manual moved will start to spin? seems very odd?
Check the current drawn by the motor when it goes on spin. If it's more than it's written on the motor label, replace the motor. If it's not, then the problem most likely is a bad timer. - The timer Part number: AP3712045
Rank:: Member
thanks i will check, also it seems to be operating fine when run with nothing in it? does a complete cycle when empty.....i am a bout to open it up now and see!
Rank:: Member
good news, no longer tripping breaker, agitating fine...just no spin at all now, not even with a little push, thinking i way have over tightened something , i did hit the the transmission and pieces that are supposed to move with some wd 40 to make sure they where not stuck ...i guess i am off to a hardware store to get a oem meter....
Originally Posted by: kevbayer  ...i guess i am off to a hardware store to get a oem meter.... It's a good idea. You can check the motor and the timer, using the wiring diagram. Gene.
Washer Repair
