Neptunelea
#1 Posted : Wednesday, February 24, 2010 2:13:49 PM(UTC)
Neptunelea
My washer turns on and puts water in the tub then counts down like normal, but doesn't wash. It has the water in the tub and then nothing. Water stays in the tub and panel counts down as if nothing was wrong.:confused:
magician59
#2 Posted : Wednesday, February 24, 2010 6:59:37 PM(UTC)
magician59
You'll find a tech sheet inside the console. Follow the diagnostic mode directions. Post your results.
Neptunelea
#3 Posted : Wednesday, February 24, 2010 8:29:16 PM(UTC)
Neptunelea
Ok, so to remove the consule, I take out the 4 screws in the back and lift it or do I need to remove something else? Then I will find the instructions inside? Thanks
