Good day all, I received a replacement ERC from here at APP. The original part WB27K5107 is no longer available, replaced by WB27K5140. Here's the electrical connections I had on the original part: Green -> GND/E6 Blk/Wht -> NO/E8 Black -> C/E9 Double White -> N/E7 Purple -> BR/E5 Black -> L1/E4 Yellow -> BA/E3 (also multiple pin connector on end) In other words, the back of the ERC has spade connectors with two labels each. The NEW ERC has slightly different labels: GND/E7, NO/E8, COM/E9, NEU/E6, BR/E4, L1/E5, BA/E3 No instructions came with the ERC. A couple of these obviously match up: NO/E8 and BA/E3. not-so-obvious, but I think matches up: C/E9 -> COM/E9. Now, I *suspect* that the 'E' labels just refer to a location on the circuit board, and that I really only need to pay attention to the other labels, like "GND", "BR", etc. BUT, I'd really like to confirm that first since this is a $200 part - would hate to wreck it by guessing. So, if my hunch is correct, I think the connections would be: Green -> GND Blk/Wht -> NO Black -> COM Double White -> NEU Purple -> BR Black -> L1 Yellow -> BA Is this correct??? Thanks Keith
Originally Posted by: Crashcup  Good day all, I received a replacement ERC from here at APP. The original part WB27K5107 is no longer available, replaced by WB27K5140. Here's the electrical connections I had on the original part: Green -> GND/E6 Blk/Wht -> NO/E8 Black -> C/E9 Double White -> N/E7 Purple -> BR/E5 Black -> L1/E4 Yellow -> BA/E3 (also multiple pin connector on end) In other words, the back of the ERC has spade connectors with two labels each. The NEW ERC has slightly different labels: GND/E7, NO/E8, COM/E9, NEU/E6, BR/E4, L1/E5, BA/E3 No instructions came with the ERC. A couple of these obviously match up: NO/E8 and BA/E3. not-so-obvious, but I think matches up: C/E9 -> COM/E9. Now, I *suspect* that the 'E' labels just refer to a location on the circuit board, and that I really only need to pay attention to the other labels, like "GND", "BR", etc. BUT, I'd really like to confirm that first since this is a $200 part - would hate to wreck it by guessing. So, if my hunch is correct, I think the connections would be: Green -> GND Blk/Wht -> NO Black -> COM Double White -> NEU Purple -> BR Black -> L1 Yellow -> BA Is this correct??? Thanks Keith I'm in need of this part (WB27K5107) as well. How did you get on with the replacement part? I must order it and get it sent to Costa Rica... even MORE complicated and expensive. Look forward to hearing from you.
