I am trying to figure out why my washer will not Agitate. Belts good. Spin works. Isn't there a coupler under Agitator? Please help.
What is the complete model number of the washer?
I am having issues getting the Agitator off. Is there a special way to remove it?
Thanks Gene. You have helped me alot!
I have the same problem with the same washer but the splines in the coupling don't appear to be too bad.
Replace anyway? Other suggestions?
Mine was not bad either. But I changed it and it works. Only heads up I have is when putting the new coupling on, be careful to not hit it to hard.
Got the part today and it works perfectly! Thanks for the help
