Julie Foster
#1 Posted : Monday, April 7, 2008 7:39:15 PM(UTC)
Julie Foster
I cleaned my oven and now it will not warm up...I set it to 350 and it runs for a few minutes than goes back to low. I :confused: have checked the broil element with and ometer as well as the temperture jack inthe back of the oven they show good readings..but no oven and I sure would like a pizza any suggestions?
#2 Posted : Tuesday, April 8, 2008 5:17:12 PM(UTC)
Hi Julie,
There is a thermal fuse on the back of the oven (#37 on the oven break down diagram) which, most likely, is blown due to overheat during the self clean.
You can check it for continuity as described in the tech sheets (page 5).
You have to remove the oven from the cabinet in order to replace it.
- The part number for the thermal fuse is AP3879224
Here are the break down diagrams for the kitchen Aid oven Model KEBC107KWH0
P.S. I would recommend not to use the self clean in the future.
Julie Foster
#3 Posted : Wednesday, April 9, 2008 5:57:13 AM(UTC)
Julie Foster
Thanks Gene!!!:)
Since reading this site I now realize self cleaning is a no no. I will try this and hopefully it works!!
Julie
#4 Posted : Wednesday, April 9, 2008 12:32:26 PM(UTC)
Keep me updated, please.
Julie Foster
#5 Posted : Friday, April 11, 2008 12:32:19 PM(UTC)
Julie Foster
Well another sucess story thanks to this web site.
Gene...
Thanks for your help and advice.. It ws the therm- fixx and my oven is up and running:) :) :)
I have been referring people to this site for help and parts and I will continue to use this site when needed..
Very happy:) :) new custoner
Julie Foster
Anderson, California
