jakubowa
#1 Posted : Tuesday, February 23, 2010 4:56:54 PM(UTC)
jakubowa
dryer won't start. door shut. light works. can hear timer when button is hel down
#2 Posted : Wednesday, February 24, 2010 2:49:49 AM(UTC)
Replacement parts for WHIRLPOOL LER7646JQ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406692.pdf
Could be that the thermal fuse on the blower wheel (Item 7 in Section 3) has blown.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
dry won't start (Dryer Repair)
by bahawki57 11/12/2013 6:53:42 AM(UTC)
Dry won't start (Dryer Repair)
by Dennis Carpenter 12/12/2010 2:32:17 PM(UTC)
