Hello, have been noticing that the fabric softener cup on the top of the ajitator doesnt empty. Softener is still in there after the wash is finished. Any place I should look first. thanks for your time.
Pull the cup out, take it apart and clean it.
thank you Gene, I pulled up on the cover and inside is a funnel with a closed bottom. The cup the funnel sits in, with the slot in it, was filled with dirt. I will try it later today.:)
