Archfsc
#1 Posted : Sunday, August 3, 2008 5:45:53 AM(UTC)
Archfsc
Have small leak only during wash cycle coming from under center panel door. Btm seal on panel to tub looks good. Looks like its coming from inside door and dripping down. Is this possible?
fixxit
#2 Posted : Sunday, August 3, 2008 10:34:25 AM(UTC)
fixxit
it is possible that you may have a couple of loose screws in the top of the pump body that jets water towards the door. remove the spray arms and using t-20 torax bit tighten the screws. then replace the spray arms. this should fix your problems
DesertDeuces
#3 Posted : Sunday, August 3, 2008 7:34:12 PM(UTC)
DesertDeuces
You might not have a leak in your door seal. It could be your sprayer arm is leaking at the seams. The front door does not completely seal at the bottom because the washer needs to vent. The bottom has a deflector, not a seal.
Take your sprayer arm out of the dishwasher and place a garden hose at the water inlet end of it. Turn on the hose. The water should only exit at the sprayer nozzles. If it sprays out at the seams, replace the sprayer arm.
Also, to prevent wate leaks through the door, always load plates in the back and bowls in the front. Tall items in the front of the basket can cause the water to deflect and spill out through the bottom of the door.
jun14
#4 Posted : Tuesday, February 23, 2010 7:04:19 AM(UTC)
jun14
I bought aWhirlpool dishwasher last week. There is no leakage in the first two usage. However, after using dish detergent, the foam come out of the bottom of the front door, which causing water leakage. How should I prevent this? I don't want to return and reinstall, which takes me several hours. thanks. --Jun
Guest (4)
