burganva
#1 Posted : Tuesday, February 23, 2010 4:42:43 AM(UTC)
burganva
My Dishwasher will drain but will not fill for the wash cycle. I sprayed water inside to see if it would work but it only made a loud sound like it was trying to wash and no water was being sprayed around. I checked the supply hose and it was on. Is there a common fail item that has been ordered multiple times for this type of problemand do you have any idea of how to troubleshoot and narrow the fault? Thanks.
magician59
#2 Posted : Tuesday, February 23, 2010 6:40:12 AM(UTC)
magician59
First, check the water supply. Is there any water from the source to the inlet valve? If so, is the valve receiving 120VAC to open it?
