LarryDon
#1 Posted : Monday, February 22, 2010 8:10:51 PM(UTC)
LarryDon
Error code F2-E4
According to Error code sheet given to me by tech:
Tech unable to find keypad Switch assy
Codes reappeared after replacing part. Oven will come on before error code appears.
FAULT PRIORITY: 6
FAULT CONSTANT NAME IN SOFTWARE:Keys unsettled
FAULT DESCRIPTION: Keys unsettled probably due to noise
FIELD SERVICE ACTION: Press Cancel. Remove electrical noise source. If reappears replace KEYPAD SWITHC ASSY (purchased from Repair ************)
Looking for any suggestions, wife without oven before Turkey day.
Thanks,
Larry
#2 Posted : Tuesday, February 23, 2010 4:49:40 AM(UTC)
Cooktop, literature replacement parts for WHIRLPOOL KERC607HWH0 | AppliancePartsPros.com
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ff6fd32da573564a85256f0e0048243d/$FILE/KAELECTRANGE.pdf
[COLOR="Blue"]
Error code F2-E4
Codes reappeared after replacing part. Oven will come on before error code appears.[/COLOR]
Not sure what part was replaced if any. You said "Tech unable to find keypad Switch assy" but then say "Codes reappeared after replacing part".
Please clarify.
Sounds like one of the elements is generating electrical noise.
Could be a bad connection to one of them.
try broil only etc. to see if you can narrow it down.
Also if a fan is coming on, it could be the source.
