Jimmyd
#1 Posted : Monday, April 7, 2008 12:46:39 PM(UTC)
Jimmyd
Original problem-NO Heat. Replaced Main Coil-Got Heat, but no Hi Heat on Cotton cycle. Ordered & replaced the following parts: op hi & op lo thermostats, cycling thermo hi temp, and heat(flame)detector. NO change in the heat(still low). Did I miss a part??? Thanks.
#2 Posted : Tuesday, April 8, 2008 11:51:18 AM(UTC)
Most likely the problem is a clogged vent outside the dryer and/or the air ducts and the blower wheel inside the dryer.
