Hi, I have refrigerator by Frigidaire model# FPCI21TCW1 that the door gasket is torn at the bottom and leaks. I bought a replacement for it. I'd like to know what to expect on the install. Does it snap into a slot? Or does it install by other means? Thanks, :confused:
Hi, the repair went well with the refrigerator gasket. I'm sure the gasket sealed great and appears to have no leaks on it. However I still have a small leak coming from somewhere underneath the hinged side of the door. All the leaks started after having the floor retiled. Any ideas as to what it could possibly be? Thanks for your help!
Check the drain pan under the fridge.
Hi, can you tell me how to drain the drain pan on the Frigidaire model# FPCI21TCW1? Thanks
It should be under the fridge. Just remove it.
