roncasl
#1 Posted : Tuesday, April 8, 2008 7:26:54 AM(UTC)
roncasl
Right rear burner will not heat on "warm setting". All other positions are OK. Is it the switch or the burner?
roncasl
#2 Posted : Tuesday, April 8, 2008 10:26:08 AM(UTC)
roncasl
It was the switch. I turned it to the warm position and pushed the stem hard to one side and the burner worked while I held it there.
Cooktop burner not working-How do I know if its the burner or switch? (Oven Repair (including Ranges and Cooktops))
by joelake 1/12/2011 6:03:05 AM(UTC)
Burner or switch? (Oven Repair (including Ranges and Cooktops))
by cater 7/15/2010 1:50:07 PM(UTC)
Burner or Switch (Oven Repair (including Ranges and Cooktops))
by BurchillB 7/25/2008 1:39:40 AM(UTC)
