john77oh
#1 Posted : Friday, February 19, 2010 6:11:17 PM(UTC)
john77oh
Model 97591240
sensors mounted on the flame chamber and the igniter show continuity but get no ignition/glow from igniter.
All vents are clear. Gas is on and to the dryer. Power is on, drum turns and timer cycles properly. suggestions?
Qtip
#2 Posted : Friday, February 19, 2010 6:31:52 PM(UTC)
Qtip
check the black valve coils for continuity
john77oh
#3 Posted : Friday, February 19, 2010 7:29:40 PM(UTC)
john77oh
valve coils check ok, 500 to 1000 ohms
Simon / APP Team
#4 Posted : Tuesday, March 27, 2012 6:18:26 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, John.
Most likely the problem is bad thermal fuse.
It's located on the blower housing.
With the dryer unplugged get the toe panel off , take one wire off the fuse and check for continuity. If it's open - replace the fuse.
The thermal fuse Part number: AP3133489
Thank you. Post the results.
kenmore gas dryer not heating (Dryer Repair)
by car14 6/7/2010 12:24:12 PM(UTC)
