Before I buy one on line. Is this hard to install. I was looking for some diagram. step By step.
If this clamp is a wire clamp used for the Whirlpool Duet, it is a bit difficult to put on. Adjust the screw till the gasket just barely slips in the front panel groove. I helps to smear some liquid soap on the gasket. Have some patience, you will eventually get it on all the way around.
