glund
#1 Posted : Friday, February 19, 2010 10:16:00 AM(UTC)
glund
Hi, my refrigerator has developed a buzzing noise, I think it is the defrost timer? but not really sure. Freezer side cools to zero, frig side to 30 or so, but then this buzzing noise starts, the temp goes up in the freezer. I left it unplugged for about 3-4 hrs. then plugged it back in the temp came right down then the buzzing noise started again. It sounded like it was coming from around the compressor. Thank you in advance for any help, Geoff
ApplianceJunk
#2 Posted : Friday, February 19, 2010 11:44:14 AM(UTC)
ApplianceJunk
It maybe the start relay on the compressor that you are hearing.
If so the start relay should be replaced.
glund
#3 Posted : Friday, February 19, 2010 2:59:13 PM(UTC)
glund
Thank you, I have just put in a new start relay, I hope the problem is solved. Thanks again for the help Appliance Junk!
ApplianceJunk
#4 Posted : Friday, February 19, 2010 3:24:40 PM(UTC)
ApplianceJunk
Thanks for the update.
