4 Pages<1234>
#21 Posted : Thursday, April 3, 2008 10:22:38 PM(UTC)
Based on my experience and this forum, the rate of success for ice makers repair is less than 40%.
It is very possible you will spend a lot of money buying parts and finally end up buying a new ice maker.
If you would like, we can proceed with the troubleshooting for the ice maker, trying to fix it. It's up to you.
Jmorgando
#22 Posted : Saturday, April 5, 2008 5:38:59 AM(UTC)
Jmorgando
I need HELP!!!
I replaced the ICE maker and the Inlet water valve and now there is no water comming out going into the icemaker.. Now What?????:(
Pete blocker
#23 Posted : Monday, April 7, 2008 1:15:13 PM(UTC)
Pete blocker
Gene the model no is et1fhtxmq02 .
The ice maker could not get water. I replaced the water valve and checked to to make sure water was getting to the inlet at the back of the refrigerator it was. The local repairman hook it up to his refrigerater the ice maker would take water but did not harvest .the heating unit worked but did not empty. please advise
Pete blocker
#24 Posted : Monday, April 7, 2008 1:30:12 PM(UTC)
Pete blocker
:confused:
#25 Posted : Monday, April 7, 2008 2:21:54 PM(UTC)
Hi Pete,
The cause of the problem could be a bad motor or a bad ejector.
I would recommend to replace the whole ice maker.
- The part number for the ice maker is AP2984633
#26 Posted : Monday, April 7, 2008 2:26:50 PM(UTC)
Hi Jmorgando,
Check all connections. Make sure the water feeding tube into the ice maker is open.
AustinBrooks
#27 Posted : Sunday, October 4, 2009 1:11:49 PM(UTC)
AustinBrooks
Hey gene,
My whirlpool icemaker quit working. I have replaced my water inlet valve and tested it at the module. Doing this i got water into the icemaker but it wont do it by itself.
Any suggestions?
#28 Posted : Sunday, October 4, 2009 1:34:21 PM(UTC)
Sounds like the ice maker itself is bad.
- The ice maker Part number: AP2984633
AustinBrooks
#29 Posted : Sunday, October 4, 2009 3:01:53 PM(UTC)
AustinBrooks
does the icemaker come with a new module on it?
AustinBrooks
#30 Posted : Sunday, October 4, 2009 6:50:24 PM(UTC)
AustinBrooks
So the icemaker tells the water valve when to bring water up to it?
Whirlpool Icemaker problems (Refrigerator & Freezer Repair)
by mw_98 2/13/2011 5:47:44 AM(UTC)
4 Pages<1234>
