fldad1
#1 Posted : Thursday, February 18, 2010 4:42:35 PM(UTC)
fldad1
The power cord wire that connects to the top terminal block shorts out which causes the line to burn and a open line occurs which stops the dryer. This same problem happen about a month ago and the repair man put in a new power cable and a new terminal block and it work fine for about a month, and has now it has shorted out again. What would cause this to happen twice and how can I check to see what is causing the problem.:confused:
Thank you,
R Shook
magician59
#2 Posted : Friday, February 19, 2010 5:51:13 AM(UTC)
magician59
There may be a loose or shorted connection internally. First place to check would be right where you're seeing the scorches at the terminal block.
