My dad took out the motor for my grandmas dryer. He repaired the motor but now doesn't know how the wires connect back to the motor to have the dryer run. I cannot find a manual online anywhere simply because the dryer is too old, and obviously it is the only manual that my grandma hasn't kept:(. It is a 1975 Maytag dryer Model Number DG306 and serial number 699173. Any suggestions would be greatly appreciated, once the wiring is completed it should work, we just don't know which wire goes where.
Did you look for the wiring diagram inside the control panel?
Also it suppose to be a colored marks on the motor centrifugal switch.
