info@georgiainsuranceagen
#1 Posted : Monday, April 7, 2008 10:21:23 AM(UTC)
Fan blowing. Some cooling in lower freezer. Non in fridge.
I have pulled apart the back of unit but dont know what I am really looking for or at. I suspect issue is condenser. Comments?
Is there an online manual where I can see schematics for parts?
gearhead1218
#2 Posted : Monday, April 7, 2008 4:52:07 PM(UTC)
gearhead1218
Need more info.
Is the freezer compartment all frosted up?
If so, and the Evap. fan motor is working, then you have a defrost issue. Either timer, termination stat, or heater element.
If your compressor is trying to start, but humming and clicking, then it is bad.
If your compressor is running but quieter that normal, then you most likely have a sealed system issue.
Is the condenser fan in the back working?
Condenser coil clean and not full of animal hair?
#3 Posted : Tuesday, April 8, 2008 7:05:00 AM(UTC)
Coils are cleaned. Fan in back is running.
I placed two bottles of water in freezer. One on top shelf is not freezing. One on bottom does freeze. Fridge isnt cooling
gearhead1218
#4 Posted : Tuesday, April 8, 2008 12:31:16 PM(UTC)
gearhead1218
Is the fan in the freezer working?
GE Freezer/Fridge not cooling (Refrigerator & Freezer Repair)
by bjorkmd 3/18/2013 10:09:53 AM(UTC)
by lc21805 7/9/2011 12:13:18 PM(UTC)
Top of freezer/fridge not cooling (Refrigerator & Freezer Repair)
by freya 7/4/2011 5:32:44 AM(UTC)
freezer/fridge not cooling after brief power outage (Refrigerator & Freezer Repair)
by kaminski 5/31/2011 11:40:27 AM(UTC)
GE side by side Freezer/Fridge not cooling well (Refrigerator & Freezer Repair)
by dustin1976 9/20/2009 9:43:18 AM(UTC)
Bottom mount freezer/fridge not cooling Properly (Refrigerator & Freezer Repair)
by Gwaii 4/9/2009 9:56:03 AM(UTC)
