billyt
#1 Posted : Monday, February 15, 2010 6:22:02 PM(UTC)
billyt
The washer stops sometimes during the final spin cycle, it is happening more frequently. You can usually get it stared again by pressing the cycle button to turn it off then pulling it out again to start it. You usually have to do this a few times to get it through the final spin. It may spin for a while and stop again during the final spin.
What is wrong?
sidfink43
#2 Posted : Wednesday, February 17, 2010 5:12:25 PM(UTC)
sidfink43
Probably the timer, this part here but before spending the money take off the connector and clean the connections with contact cleaner and reseat. If that does not fix it, try replacing the timer.
Part number: AP3605418
#3 Posted : Thursday, February 18, 2010 3:39:16 AM(UTC)
If the motor is running during this period, you have a worn clutch.
