Good morning everyone. I am having a probem with my washer again. I had to replace my coupler last time and it started working like a charm. It stopped spinning and agitating again though a cople of days ago. I took it apart andn saw that one of the pieces to the coupler had rounded out again. I went to get another coupler and replaced only the part that had rounded out. Well, once I put it back together and started a load it still is not spinning or agitating. also, when it was apart and i used the coupler part attached to the tranny to spin and see if the agitator spins, when I turn the coupler it turned a couple of times and the agitator did twirl a bit and then the coupler just got really stiff. It was very hard to turn. what kind of problem are we looking at ?
Originally Posted by: bounette77 Good morning everyone. I am having a probem with my washer again. I had to replace my coupler last time and it started working like a charm. It stopped spinning and agitating again though a cople of days ago. I took it apart andn saw that one of the pieces to the coupler had rounded out again. I went to get another coupler and replaced only the part that had rounded out. Well, once I put it back together and started a load it still is not spinning or agitating. also, when it was apart and i used the coupler part attached to the tranny to spin and see if the agitator spins, when I turn the coupler it turned a couple of times and the agitator did twirl a bit and then the coupler just got really stiff. It was very hard to turn. what kind of problem are we looking at ? come on guys, can someone please help me out here.
I am going to keep bumping this until I get some kind of response. My washer is in limbo right now. I need that washer like I need food. Please help!!!!!!!!ppwwweeeaaase
