cocina4all
#1 Posted : Wednesday, February 17, 2010 7:49:24 AM(UTC)
cocina4all
Melted snow ran down the vent on top of the electric stove top range, tripped the circuit braker. Went down and tried to re-set switch, tripped,again. Let it dry for a couple of days with a light in the oven. Same results. Is there an in line circuit braker or fuse somewhere in the range itself. or do I need to get a new range:confused:
magician59
#2 Posted : Wednesday, February 17, 2010 11:40:55 AM(UTC)
magician59
It sounds like you have more than just a wet short. What all DOES work, and what does NOT work, on the range?
cocina4all
#3 Posted : Friday, February 19, 2010 3:26:02 PM(UTC)
cocina4all
The water on the range triped the circuit braker, nothing works. Is there an inline fuse or a braker. Tried to re-set braker and keeps on triping out.http://forum.appliancepartspros...ges/smilies/confused.gif
magician59
#4 Posted : Saturday, February 20, 2010 9:40:19 AM(UTC)
magician59
There are no fuses in a range. You have a dead short somewhere in the system. Do you own a meter? Can you do continuity checks?
cocina4all
#5 Posted : Saturday, February 20, 2010 9:23:49 PM(UTC)
cocina4all
yes have acess to one. Start at the switchs and go from there or, how do I go about it. Thank you
