fw2000
#1 Posted : Tuesday, February 16, 2010 6:56:57 AM(UTC)
fw2000
Water fills, heats, and pump drains unit.
Timer completes full cycle.
Door latch will start timer as usual.
When timer hits wash or rinse cycle there is nothing.
No click,
No hum,
And no spraying action.
Any insight appreciated. Thanks
#2 Posted : Tuesday, February 16, 2010 8:30:48 AM(UTC)
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154521601.pdf
Check across the motor for voltage during the wash.
If it is getting 120 volts then your motor is probably toast.
Part number: AP4312350
If it is not getting voltage.
Remove the inner door panel and the wires from the motor.
Then check the wires for continuity up to the control board.
Could be a wire has broken internally.
If all OK
Then probably your timer is toast
Part number: AP3214650
Here is a manual which should be a close match to your unit
http://frigidaireservicetips.com/pdfs/485_3.pdf
