rcmizen
#1 Posted : Saturday, September 22, 2007 2:59:24 PM(UTC)
rcmizen
OK, so this is a bottom of the line (like not even a clock!) range that came with our recently purchased house. Problem is that all 4 of the burners are 9500BTU units that won't allow a simmer even on the lowest heat (making rice is out of the question). So the question is, can I convert one of the burners to a lower heat output? If so, how much do I need to replace - just the burner top, just an orifice or both? Or more? -- Thanks!
rcmizen
#2 Posted : Saturday, April 5, 2008 4:51:12 PM(UTC)
rcmizen
Bump...
Can this be done or do I just need to save up for a new range???
