bobs
#1 Posted : Monday, February 15, 2010 10:39:18 AM(UTC)
bobs
My freezer is defrosting so long it melts the ice and refreezes on the inside of door and bottom of freezer. The temp in the refirgerator is warmer that I think is should be but might be a result of this defrost timing issue. I have already replaced the mother board. Please help. Thanks
#2 Posted : Monday, February 15, 2010 12:39:09 PM(UTC)
Replacement parts for General Electric GSS25WGMDBB Refrigerator | AppliancePartsPros.com
Sounds like the defrost thermostat is toast. It is supposed to turn off the heater once the ice/frost is melted off the coils.
Part number: AP3884317
#3 Posted : Tuesday, February 16, 2010 1:06:58 AM(UTC)
Is the freezer fan running during defrost? Rather rare the defrost thermostat shorts, I would suspect something else.
#4 Posted : Tuesday, February 16, 2010 9:39:04 AM(UTC)
Here is a manual with a pretty good description of how the defrost cycle should run.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
See Page 54 for the thermistor specs.
bobs
#5 Posted : Friday, February 19, 2010 5:00:02 AM(UTC)
bobs
Ok I repalced the defrost t-stat and it seems to have helped but still seeing a little bit of ice melting and refreezing them together???
#6 Posted : Friday, February 19, 2010 5:12:33 AM(UTC)
I would replace both freezer thermistors, short plastic white items, one on top of the evaporator and one on the bottom.
