2 Pages<12
gregbreitz
#11 Posted : Tuesday, August 28, 2007 4:27:01 PM(UTC)
gregbreitz
If the gas valve coil is bad,it will not operate even once...
Admin / APP Team
#12 Posted : Wednesday, August 29, 2007 6:38:51 AM(UTC)
Admin / APP Team
Rank: Administration
Groups: Guests
Dryer gas valve coil can do the job the first time and then fail to completely energize afterwards - a common problem.
mell276
#13 Posted : Friday, December 28, 2007 5:10:23 PM(UTC)
mell276
I checked my circuit breakers and they are fine. The 3-prong outlet works and is fine. My dryer runs and runs and never gets hot and never turns off. It has to be shut off manually. I have replaced the following
and cleaned out all lint from everywhere. Am I missing something? Please help.
AP3094244 (279816) - Thermal cut-off for dryer heating element 309 degrees (includes high-limit thermostat)
AP3132867 (3392519) - Thermal fuse (disposable, one time fuse)
AP3131941 (3977767) - Thermostat, fixed
AP3094254 (279838) - Dryer heating element
AP3131939 (3387134) - Dryer cycling thermostat, L155-25
:confused:
2 Pages<12
